Hi Ray,
The board should accept commands before during and immediately after the init download so I doubt if that is the issue.
When does it happen on connect or disconnect. Seems like a disconnect is a possibility if you are just getting status every 100ms and that is setting the connected/disconnected state then if the disconnect happens mid way between status checks and then something decides to do a GetDigitalValue after the disconnect but before the next status the it would fail.
Message: 2911 |
Date: 1/2/2012 |
Subject: Re: Connection Management.... |
Hello Ray, On the exception while exiting, this may help:: In your Form OnClosing() First) Stop your timer Second) Dispose of the controller I suspect you are disposing the controller and the timer is still chugging along and eventually encounters a disposed KM_Controller object. -Brad Murry From: DynoMotion@yahoogroups.com [mailto:DynoMotion@yahoogroups.com] On Behalf Of himykabibble Sent: Monday, January 02, 2012 10:31 PM To: DynoMotion@yahoogroups.com Subject: [DynoMotion] Re: Connection Management.... Brad,
OK, that appears to be working. However, with the Dispose call in the OnClosing event, and no board plugged in, KM_Controller.Dispose is throwing an un-handled exception exception when I close my window.
I'm also frequent exception from GetDigitalValue when the connection state changes. Since I have all of my calls to ANY KM_Controller methods surrounded with a test to ensure the board is connected, AND my init download has completed, this suggests there is some time required AFTER doing the init download before the board is really ready to run. How do I determine it's really and truly fully up and running?
Regards, Ray L.
--- In DynoMotion@yahoogroups.com, "bradodarb" <bradodarb@...> wrote: > > Hello Ray, > > That is correct. > > -Brad Murry > --- In DynoMotion@yahoogroups.com, "himykabibble" <jagboy@> wrote: > > > > Brad, > > > > So, if I'm understanding correctly.... The Axis and IO setup can be done once, but must be done WHEN connected. But subsequent re-connects can simple download the Init.c, and that's it? > > > > Regards, > > Ray L. > > > > --- In DynoMotion@yahoogroups.com, Brad Murry <bradodarb@> wrote: > > > > > > Hello Ray, > > > > > > > > > > > > I must have been unclear, sorry about that. > > > > > > > > > > > > What I meant was do everything you are doing(monitoring connection, etc.) > > > but when you reach the point of detecting a loss of connection and then a > > > reconnect just call your init files and that's it. > > > > > > > > > > > > -Brad Murry > > > > > > > > > > > > From: DynoMotion@yahoogroups.com [mailto:DynoMotion@yahoogroups.com] On > > > Behalf Of himykabibble > > > Sent: Monday, January 02, 2012 9:21 PM > > > To: DynoMotion@yahoogroups.com > > > Subject: [DynoMotion] Re: Connection Management.... > > > > > > > > > > > > > > > > > > Brad, > > > > > > If I try to do a full init with no board connected, I get tons of exceptions > > > when doing the axis and IO setup, which is why it seemed to me I HAD to have > > > the board present to do that. > > > > > > Regards, > > > Ray L. > > > > > > --- In DynoMotion@yahoogroups.com <mailto:DynoMotion%40yahoogroups.com> , > > > "bradodarb" <bradodarb@> wrote: > > > > > > > > Hello Ray, > > > > > > > > I would just call the init on reconnect, there should no need to reinit > > > everything. > > > > > > > > -Brad Murry > > > > > > > > --- In DynoMotion@yahoogroups.com <mailto:DynoMotion%40yahoogroups.com> , > > > "himykabibble" <jagboy@> wrote: > > > > > > > > > > I'm finding connection management rather bothersome. I've modified my > > > constructor so it creates the KM_Controller object, then, every 100 mSec I > > > call a method that compares the current Connected state to the previous (100 > > > mSec ago). If it WAS disconnected, and IS now connected, then I re-initalize > > > everything (creating new Axis and IO dictionaries), then download my Init.c. > > > But, I'm finding I get frequent errors when the board comes or goes. > > > Sometimes I'll get an error from a ReadDigitalIO call, complaining about a > > > null reference, or an exception from within KMIO due to an invalid return > > > value. And, of course, I've had to litter my code with "if > > > (KMController.Connected)", so I don't try to talk to a board that isn't > > > there. > > > > > > > > > > Can I get some pointers on how to correctly handle this, so I handle > > > connection state changes cleanly? > > > > > > > > > > Regards, > > > > > Ray L. > > > > > > > > > > > > > > >
Message: 2914 |
Date: 1/2/2012 |
Oddly, it seems to happen most persistently on a re-connect. I can see there is still going to be a problem on asynchronous disconnects. I'm not currently trapping any exceptions, so I still need to put a bunch of try/catch's in.
Ray L.
> Hi Ray,
> TKÂ
> Sent: Monday, January 2, 2012 9:31 PM
> Brad,
> Regards,
> Ray L.
> > Hello Ray,
> > That is correct.
> > -Brad Murry
> > > Brad,
> > > Regards,
> > > Ray L.
> > > > Hello Ray,
> > > > -Brad Murry
> > > > Brad,
> > > > Regards,
> > > > Ray L.
> > > > > Hello Ray,
> > > > everything.
> > > > > -Brad Murry
> > > > there.
> > > > > > Regards,
> > > > > > Ray L.
Message: 2915 |
Date: 1/2/2012 |
Brad,
Nope, that's what I was already doing. I now have a flag that tells me the one-time init (defining axes, I/Os, etc.) has been done, and if that flag is not set, I just don't call KM_Controller.Dispose(). The one-time init is done as soon as I see Connected go true after the app starts. That all seems to be working OK now. But I'm still getting frequent exceptions coming from GetDigitalValue on disconnects and re-connects.
Ray L.
> Hello Ray,
> First)
> Stop your timer
> Second)
> -Brad Murry
> Brad,
> Regards,
> Ray L.
> > Hello Ray,
> > That is correct.
> > -Brad Murry
> > > Brad,
> > > Regards,
> > > Ray L.
> > > > Hello Ray,
> etc.)
> then a
> > > > -Brad Murry
> > > > From: DynoMotion@yahoogroups.com <mailto:DynoMotion%40yahoogroups.com>
> [mailto:DynoMotion@yahoogroups.com <mailto:DynoMotion%40yahoogroups.com> ]
> On
> > > > To: DynoMotion@yahoogroups.com <mailto:DynoMotion%40yahoogroups.com>
> > > > Brad,
> exceptions
> to have
> > > > Regards,
> > > > Ray L.
> <mailto:DynoMotion%40yahoogroups.com> <mailto:DynoMotion%40yahoogroups.com>
> > > > > Hello Ray,
> reinit
> > > > everything.
> > > > > -Brad Murry
> my
> mSec I
> previous (100
> re-initalize
> Init.c.
> about a
> return
> isn't
> > > > there.
> handle
> > > > > > Regards,
> > > > > > Ray L.
